12-05-2021, 05:20 PM
I bought an engine reputed to have been rebuilt about 15 years ago, dry stored and turned frequently on the handle. The rebuild was done for a client by someone I have not heard of before the surname being Orange or possibly the company, in the Midlands?
It arrived in seemingly excellent condition, complete with rebuilt dynamo, starter, dizzy, 1 1/8"th SU carb, new HT leads, new fastenings every where, painted, filled with oil and said to contain a Phoenix crank etc, it had a blanking plate over the fuel pump location. It had compression on turning by hand, so I decided not to take it apart but hope that it was going to run as well as it looked, I fitted a pump.
I installed it into my RP and connected everything. Turned the engine by hand to start the oil around the galleries, spun it on the starter without ignition until I had oil pressure. Switched on and it started, a small adjustment to the finger tight dizzy and it ran quite nicely for 30 seconds. Then there was a scuffing noise in time with the rotation, which lasted about 1 minute, did not sound serious but as if components were getting used to one another, which then stopped and the engine ran for about 2 minutes before beginning to slow and then stop. Following which it now runs on only 2 and 4. I have drained and refilled the tank to remove old fuel. I have swapped plugs, leads, caps and tried 2 different dizzies known to work ok, I have sparks at all 4 plugs. I can remove plugs 1 & 3 and it runs quite happily on 2 cylinders. I checked compression 115psi on 1 and 0psi on 3? So now I am thinking stuck valves perhaps on 3 or the cotter dropped out of the valve stem, but that does not explain 1 not firing?
I have had to pack it in for the day and am out tomorrow, so instead of ripping into it I thought I would ask if there is something you think I might have missed in diagnosing the problem. I am thinking that my next move will be to remove the manifold and valve chest cover to see what is happening in the valve department. However you may have better ideas, if so I would be grateful for the assembled wisdom please.
Thank you in anticipation
Jack
Jack
