Ulster starter button
Hi All,
I have two starter buttons, both to fit the recessed surround next to the tunnel. I had one and sourced another because the first one I discovered, was incorrect. One has a brass screw on the top of the button, the other does not. Now, due to my forgetfulness, I can't remember which is correct for a 1931 EA Sports.
Erich in Mukilteo
I think it's the one with the brass screw in the button, the one without was introduced in early 1932 Erich
This is an early 1931 car...
Thank you Dave and Ruairidh. The one with the screw it is!
Erich in Mukilteo
