07-03-2021, 07:04 PM
Hi all,
Before starting a repair attempt thought it might be wise to get your views! My original Bluemels wheel is in pretty good condition with the exception of a few small areas. To prevent further loss of coating and stop the areas snagging in use I planned on painting the metal black then applying some clear epoxy to seal it and stick the black plastic coating edges....
Thoughts? Certainly don’t want to have it recovered as areas in question are small!
