The AC pumps on Sevens and contemporary cars usually have a priming lever. The return spring is horseshoe shaped and nests under the lever. I have couple of pumps where the spring is broken. Please are there any suggestions where replacement springs might be obtained. There is nothing in the Red Cross Directory and I have yet to find these with my regular suppliers of parts.
Ron
Ron, you can use these pumps with a broken spring. Mine has been broken for the last 7 years and like you I cannot find a replacement. Just move the priming lever up and down manually but remember to make sure it’s in the downwards position when you have finished.
John Mason.
Or in the up position as an anti theft device.
Thanks Dicke65. I had never though of that.
John Mason
