I have an early coil engine that I obtained without a fan. I have 2 fans of opposite hands in stock. One is marked 1A 253 and the other is not so clear, but I think reads L 1025. Which is the coil and which is the Mag engine fan?
Thanks in anticipation..............
Thanks - that's a brilliantly quick reply! Is that 4 bladed fan an "export model"?
Hi Ruairidh,
Sorry for change of subject regarding the Dynamator on the coil engine, are you happy with its performance.
cheers colin
20-12-2017, 09:59 PM
(This post was last modified: 20-12-2017, 09:59 PM by Ruairidh Dunford.)
Bob,
the coil one is an export one, the mag one was made by John Barlow for me - I don't think they made a 4 blade mag fan originally but somebody will know for sure. P.s. I will buy the Mag. blade off you if you have no use for it!
Colin - I have answered in your separate post but essentially - yes!
I have a selection of two and four bolt export fans (I think they were given to us by Ronnie Heggany and Bill Sheehan) - but none are like yours Ian, it is very curvaceous at the ends!
