10-02-2021, 11:51 PM
Hi I have a 29 chummy and I would like to make a reverse gear catch like it would have had on the gear lever. Could anyone help me with some pictures and/or maybe some instructions/suggestions.
a7 reverse catch lever
Hi,
This is not on an A7 but as your question is quite open here's what I made for the same purpose on my Sandford's gearbox. The reverse is left/front and the first rear/front so I was really afraid to break the gearbox if I missed the 1st to second. Hope this help. Renaud Of course the gear lever is very short and that allows me to push with my little finger to unlock.
11-02-2021, 07:22 PM
(This post was last modified: 11-02-2021, 07:23 PM by Parazine.
Edit Reason: grammar
Here you go. Made from German Silver about 3/64" thick I think. 1 1/2 inches across at the widest part, 1 3/4 inches from below the rivet to the top.
Photos from my 1929 saloon. DSC_0984s.JPG (Size: 23.29 KB / Downloads: 357) DSC_0985s.JPG (Size: 18.7 KB / Downloads: 357) DSC_0986s.JPG (Size: 26.28 KB / Downloads: 357) DSC_0988s.JPG (Size: 24.59 KB / Downloads: 357) Worth keeping an eye on eBay, sometimes chopped gear sticks come up or even a reverse catch.
Thanks to both of you I will keep an eye out for one and will see what I can whip up. Another question I forgot to ask is how does the bottom portion work?
12-02-2021, 12:52 AM
Ah! Another photo required but it'll have to wait until tomorrow to venture into the icy garage!
12-02-2021, 01:48 AM
cool thanks
12-02-2021, 02:32 AM
(This post was last modified: 12-02-2021, 02:35 AM by Tony Press.)
From the A7CA website:
Austin Seven Online Archive - Austin 7 Clubs' Association | (a7ca.org) List of Spare Parts: PL_670A.pdf (a7ca.org) Page 30 shows deatils of the gear lever assembly.
12-02-2021, 10:14 AM
12-02-2021, 12:05 PM
Here you are:
The first two show the catch raised and in reverse, the third is in neutral. DSC_0995s.JPG (Size: 36.68 KB / Downloads: 181) DSC_0997s.JPG (Size: 30.85 KB / Downloads: 181) DSC_0999s.JPG (Size: 31.65 KB / Downloads: 181) The guide housing often remains, rivetted to the gearstick. There is a small coil spring inside to pre-load the catch. I've reproduced the brass piece from a piece of (I think) 1/4" brass plate with a file, doesn't take long even with a few duff attempts first. Pictures of a spare gearbox, hauled out of one of my famous sheds.
12-02-2021, 09:23 PM
If they needed a reverse catch on the early 3 speed boxes why was it deleted on the later ones?
