Thanks Reckless. What about bracket D? Any idea?
Can't help you there. I don't think mine has one. It looks like it's intended as something to prevent a spacer from being crushed?
Yes, I think so too. I have just been out to trial fit the thing and the plot thickens -
The wiper motor fixing holes in the top windscreen rail are obscured by the top of the lip of the windcreen aperture when the windscreen is shut. There's no way the motor will fit as the spindle and screw threads will prevent the screen closing properly. I'm going to have to have a look at someone else's car to figure this one out.
I'm pretty sure 'Bracket D' goes on the outside of the windscreen; the two tabs prevent the wiper arm from being turned too far when parking the switch.
I am pretty sure you are correct Mike. There is a take off on the manifold that has been blocked so I guess that is for the vacuum unit. However I still don't see how the unit fits with the aperture lip in the way. I have a mate with a Box and vacuum wiper so shall investigate.
Aha! Thanks for the photos. The modification is what I am missing. I feel a grinding moment coming on...
