Car type:
interesting wiring loom solution for the engine bay - quite ingenious. I saw the Dorset Club advert online for that car I think, and it looked like it had been methodically sorted in its time with the last owner.
I suspect there's a digit missing from the given engine number...
The engine number recorded is 19454, so yes a missing digit.
Hi Alex, I am considering building a special. I like the look of your car. Can I ask you to take a few photos of the rear end and from the seats backwards to show the back end detail.
16-12-2017, 02:57 PM
(This post was last modified: 16-12-2017, 02:59 PM by Reckless Rat.)
Seems a nicely made special but does it not get a bit hot under the bonnet? - seems to be a bit short on vents to me (basing my comments on how hot it gets in my RP when it's working hard).
I do think that a special looks best when made using a short chassis. I don't know what it is (perhaps it's just me) but the proportions always seem to look stretched on a 6'9" frame, even though the saloons look fine. Perhaps it's the lowering that alters the perspective, although for a longpod like me the extra room would be welcome.
The quoted engine number would make it a 1934 crankcase.
"I don't know what it is (perhaps it's just me) but the proportions always seem to look stretched on a 6'9" frame"
I believe that is because on a long chassis you need to move or extend the steering column backwards to get the balance right and avoid the stretched cockpit appearance of so many LWB specials. That is why a SWB ulster body with a long bonnet looks so much better when fitted to a LWB chassis, on my own special I extended the column by around 4" to get the scuttle in the right place.
Hi Alex, I look forward to seeing other photos of your car. I am in the frozen north, Central Scotland.
