Car type: Austin 7 RN 1931
Whilst trying and failing miserably to remove the cylinder head of my '31 RN I noticed that the engine is tight against the bulkhead.
Its so close that I cant get to the rear exhaust nut, another part of the current job list as the manifold is cracked and needs to be changed.
I have been wondering if the engine is not the original unit.
Chassis No. 146276
Car No. B4 9473
Engine No. M 147151
I could also do with some suggestions on how to free off the head as it wont budge at the moment. I've tried spinning the engine over on the starter with the plugs in, copious quantities of release agent on the studs. If the alternator wasn't away for repair I would have tried starting it.
Hi Barry
According to “The Source book” your car is very early 1932. The chassis and engine are contemporary so it may well be the original engine.
The engine is fixed by the mounting holes in the chassis but it could be that the floor pan may not be bolted in the correct place? The engine bulkhead gap on my RK is close (about 1/2”).
It may be that engine removal may be the only way to get at that manifold nut. Once out you can have a better go at head removal.
Thanks Howardi
Removing the head
You need patience, and the firm belief that it will come off.
Also - check the forum, this has been covered before.
Amongst other things, you can put (say) a tyre lever on a head stud, hook it under a spark plug lug, and push the other end down to get some lift.
Repeat, using different studs and plugs. I think it took an hour or so before movement was detectable.
As soon as you get any movement at all, you know it will come off sooner or later.
You may have to sacrifice a plug to get enough of a lug to get your lever underneath.
Good luck.
The purists will throw up their hands in horror but years ago I made a shallow aluminium wedge that works by 'persuading' the head to separate from the block. Once initial separation has been achieved, the rest is relatively easy. Buggers the gasket but never done any damage to a head or a block!
Fox wedges - never failed, yet...
11-12-2020, 09:33 PM
(This post was last modified: 11-12-2020, 09:36 PM by Steve Jones.)
Thankfully, it's not just me then Ruairidh! Never failed me either. Last success was about 3 weeks ago.
I could not find any eye bolts of suitable thread so a couple of Ts were welded up to screw into the plug 'oles. Chain block, leaving overnight, squirting, a little patience, movement will finally take place. Mind you, a purist might think that installing an alternator has upset the entire mechanism.
