Hi All
I’m about to shorten two long wheelbase axle tubes and believe that I need to take one inch out of each. This falls in line with the difference in half shaft lengths 22 1/4” for the SWB cars and 23 1/4” for LWB cars.
However something is bothering me. The SWB track is quoted as 3’ 4” whilst the LWB track is quoted as 3’ 7”. 3” difference.
Where does the extra inch come from?
11-11-2020, 08:38 PM
(This post was last modified: 11-11-2020, 08:38 PM by Alan.)
Because track is correctly measured between centrelines of tyres where they touch the ground?
If you're narrowing a wide axle to fit a short chassis then you need to reduce the overall width by a total of 2 5/16". That means taking half of that, 1 5/32", out of each side tube.
11-11-2020, 08:49 PM
(This post was last modified: 11-11-2020, 08:54 PM by Howard Wright.)
Hi Alan
This must mean that there is difference in offset in the wheels. At the time of change between short and long wheelbase the wheels changed from closed centre to open centre. The tyre size remained the same.
Thanks Steve
Useful info as is your photos of the procedure on an earlier thread.
It still doesn’t explain why the half shafts changed by an inch rather than 1 5/32”?
Howard. You are right. I hadn’t thought that through.
Sorry, probably doesn't help, but the lengths are quoted as:
short – 22 1/4" x 0.890" dia, standard taper, 1930-31
long – 23 1/2" x 0.890" dia, standard taper, 1931-38
on the A7 Components site...
