Does anybody have paper templates of Ruby glovebox linings, or is anyone willing to PM me with dimensions, so that I can make a lining. I am assuming they are made out of some sort of thin board lined with headlining material. Any helpful info. welcome.
Thanks Ian
Car type: Ruby mk 2
Hello Ian
I have a Mk2 Ruby the glove box is formed in sheet metal.
Happy to help with dimensions if this is what you need ?
Not sure if it was originally lined ?
Tim
Car type: Ruby mk 2
After a bit of research I released what you meant.
Seen some lined with kick board.
I have used fine pile carpet in the past it provides some sound proofing as well.
Tim
On my SWB saloon which has steel glove boxes at each end of the dash, I lined them, on a temporary basis, by folding up cardboard from an old Weetabix carton (other wheat based breakfast cereals are available) which was then covered in off-cuts of the headlining cloth, turned over at the edges of the cardboard and glued to the back. The springiness of the cardboard keeps them in place and they are still there 21 years later.
I did something similar to Malcolm with my Ruby: Cut cardboard to fit inside the back, side and floor of the aperture - adjusting it until it was flat and holding itself in place - then covered the cardboard with headlining material. It has been there for years. There are rivets still place in the original sloping metal base behind the dash that suggest something more substantial was fitted originally, but it is long gone.
Colin
25-10-2020, 04:55 PM
(This post was last modified: 25-10-2020, 05:03 PM by John Mason.)
The French have a saying I don’t know what it is in French as I don’t speak the language but a rough translation is, “ There is nothing so permanent as something temporary.”
John Mason.
The glove box on my Ruby has the brown fabric lining but I would not describe the box material as cardboard it is about 3/16th thick fawn/brown in colour and particularly stiff. It could be a type of cardboard impregnated with a resin to give it strength and stiffness.
John Mason
