Laying up oil
Is it OK to bung super-cheapo oil in an engine that's not being used, with the intention of draining it out before running it again?
I was sure there was a thread about this on the forum, but couldn't find it.
Thanks
The super cheapo oils of today have API ratings far beyond oils in common use to early 1950s and by many beyond, although the rating is not primarly based on static preservative properties. Suspicious oils were some cheap re refined grades but with the fall in oil prices most have disappeared. Keeping air flow out of the engine (including waterways) assists. If the bores are not occasionally dosed with oil rings are inclined to wedge. Ideally engine should be occassionally spun on starter to toss oil around. Mind any bungs are not digested.
