1933 RP Saloon AMK 568
I wonder if anyone recognises this blue saloon? It has had quite a lot of work done on it, such as hydraulic brakes, up-rated headlamps, indicators, battery under the bonnet and a modified engine (late Ruby head, SU carb, 'bunch of bananas' exhaust, SU fuel pump, etc). The floor-pan has probably been replaced because the rear foot-wells and battery box have gone. The light blue upholstery is in very good condition, as are the headlining, sunroof and carpets. It has been in Warwickshire for about 10 years, and the A7CA Register indicates that it was previously owned by someone in the Solent A7C.
