21-09-2020, 11:48 AM
(This post was last modified: 21-09-2020, 12:27 PM by mk1-mark.)
We finally got Adam's new engine into his Cambridge bodied A7 Special at the weekend. One thing we did notice though was that there is already a bit of oil being chucked about by the front pulley seal. This is currently the normal felt type. I was wondering if anyone knows of a lip seal conversion for this area. It strikes me that a modern lip seal & easysleeve would be a far more robust option than the current set up.
Any suggestions are greatly appreciated.
Thanks, mark F
Did you soak the seal in oil for a few days before you fitted it ?
If you fit a felt seal dry it will fail almost straight away the engine starts.
I didn't build the engine. It was built by a well known specialist. The seal is well soaked. I just reckon a sleeve & lip seal will be a better option.
Are you referring to the oil seal on the front of the camshaft where it comes through the nose cone casting. My Ruby has one. It was like it when I bought The car 20 years ago and I don’t know who supplied it. I do know it works well it is more like a grommet than a seal having rubber rings each side of the central seal to keep it in place.
John Mason.
The felt seals are too thick I reduce them by a third and fit dry with silicone sealer to hold in place .Then using a syringe inject oil into the felt the next day.
Andy
Great tip on the felt thickness. I had a good look last night & don't think the recess is deep enough to take a lip seal unless the case is machined. Not something I'm prepared to do at the moment, so I think I'll try Stumpi's method.
Thank you. M
I use seal number CR 9960 or National 474250
The size is 1.00 1.686 .250
These work well as long as the pulley is not worn or the front housing that the felt wears on.
