Car type: RM Saloon
Hi All,
I had contemplated building a replacement 2-bearing engine for my RM.
I am now thinking of setting my sights a little lower and maybe replace the block, pistons and top end of the engine to reduce oiling plugs etc. I already have a replacement block rebored and honed to +40 thou. with standard new pistons to suit.
Is it practical to remove engine from the car and seperate block from crankcase and keep all the "tricky to get tolerances right" parts like crank, cam, white metal bearings etc. and replace the pistons, block, valves etc? (assuming no untoward damage is found down there)!
Sorry if this is a stupid question and I have overlooked some fundamental reason why this can't be done !
Chris
Fitting new pistons will hopefully increase power output, putting extra load on the bottom end. How sure are you (without inspection) that the bottom end will cope ?
17-08-2020, 12:30 PM
(This post was last modified: 17-08-2020, 12:32 PM by Chris KC.)
I would try to establish what is causing your specific problem then fix that.
Bores can readily be inspected / measured (at least you'll get a good idea) with the head removed (which is easy); as can valve guides.
If worn / poor condition you know what to do; if good your attention might turn to pistons and rings which on many cars can be removed without taking the block off. Rings are sometimes fitted upside down which might well cause oiling issues.
Are you sure you have the right plugs? Have you tried a compression test?
Not saying 'don't do it' but be sure of the reason to do so or you may find yourself back to square one again.
I remove engines routinely and as a matter of course, even for quite minor work. It's much easier in the long run.
Car type: RM Saloon
Thank you all for your contributions to my question.
I was intending to remove the engine, after reading a previous post regarding the pros and cons of insitu versus engine removal.
Thanks for the pictures and the thoughts on loading the bottom end with more powerful top end.
I have inspected the pistons previously and the block is at +60. I have used hotter plugs (D21). Compression good.
This will be a winter job (or lockdown) and I wanted to know if leaving the bottom end as is, but replacing the block, pistons etc was a) possible and b) advisable.
I guess its a case of 'if it aint broke' for the bottom end but happy to swop over my refurbished block and new pistons. I have limited facilities for getting alignment and tolerancing right with when it comes to bearings etc.
I removed the block, pistons and rods on my Ruby leaving the crankcase in the car. The main reason I had not long had it re spayed and did not want to remove the cowl, valance or radiator. From under the car remove the sump and big end caps noting there place for re assembly. The block can then be removed after all other stuff has been removed. The pistons come out with the block and can then be removed. Assembly is a reverse procedure.
John Mason
Whilst it is possible to do this with the crankcase still in the car, it is SO MUCH EASIER to take the engine (and/or gearbox) out of the car and do this on the bench. I can get the engine and gearbox out of my RP in less than an hour. Having recently rebuilt the top half I can testify to the fact that doing it on the bench is far less difficult ( for me at least) than crawling about under the car. In particular, when fitting the block to the crankcase with a new silicone gasket cleanliness is very important in order to avoid leaks. The joint must be clean and dry. You will find that retightening the block holding down studs and resetting the tappets is also a lot easier.
If using a silicone gasket, tighten it down and leave it overnight and then check again before removing any excess material with a stanley knife.
As Jack Reacher says. Do it right, do it once.
Car type: Type 65 1934 + RP 1932
As you are taking the engine out I think it would make sense to remove the conrods and then remove the pistons using the plugs detailed in Woodrow. I am on with this job on my RP at the moment and I am not convinced I could remove the little end clamp bolts with the rods in situ without the possibility of bending a rod. Removing the rods also allows you to check for cracks and to check the state of the white metal and the big end journals. As a matter of course I would replace the big end bolts along with new nyloc nuts. While they're out it would be good to weigh each rod to make sure they are all the same weight. One of mine was about 20 grammes more than the others, another rod was tight on the big end and I was lucky not to have run the bearing, and yet another was scrap due to a two inch crack, so they do merit close inspection!
I agree. If you don’t do it properly why bother? Interestingly, I reckon about one in every three rods I look at is cracked at the pinch bolt slot.
