22-06-2020, 12:45 PM
Tried my engine for the first time after putting it together.
Apart from the usual burning paint/sealant smells, and a louder whirring noise than usual from the timing gears, it doesn't sound too bad.
It won't idle - typically won't go below 1250 whatever I do.
Throttle stop and stop on choke lever adjusted to zero - I then took the linkage off and held the carb spindle closed with pliers.
Carb spindle one of my better ones.
Slow running adjustment appears to do almost nothing, maybe improves snap pick up a bit but doesn't affect the idle speed.
New carb to manifold gasket, new gasket plus goo between manifold and block, valves and guides are a motley collection but ok, I think.
Block and pistons pretty well worn, and not run together before, but on the road seems to pull ok.
2 bearing engine is standard apart from flattened cam followers.
What am I missing?
What am I missing?
