20-06-2020, 04:16 PM
Can anyone recommend a suitable paint for the radiator core on my 1932 Tourer? Thanks.
Paint for radiator.
20-06-2020, 05:46 PM
This is the stuff I use.
https://itstillruns.com/paint-car-radiator-6472182.html
22-06-2020, 05:42 AM
Hmm, not too sure about the 3-4 coats the article mentions. The radiator guys I dealt with [albeit on 'moderns'] blew a well thinned single coat of paint over the core. Never made a note of the product, and it was probably proprietary, but it smelt as if it had a very high VOC content, certainly it dried very quickly and looked to have good coverage. Maybe ask your local radiator repairer?
22-06-2020, 06:42 AM
I used Halfords Matt black, seems ok to me.
22-06-2020, 08:09 AM
+1 for Halfords Matt Black spray. I think it's an acrylic based paint.
22-06-2020, 10:16 AM
There is a matt/satin finish black product called "pot black" sold by motor bike shops etc, intended for engine barrels and such. I use it on the head and block. It dries quickly without leaving brush marks. No good for exhaust manifolds but ok for other bits subjected to reasonably hot temperature.
22-06-2020, 08:42 PM
Try Hammerite HIGH HEAT in Matt Balacck - designed for woodburners and such. A quick dusting over is all it takes - dries almost instantly on contact and looks 'right'.
23-06-2020, 10:51 AM
Thank you for the suggestions. I thought there might be a paint specifically for radiators, in fact I see there are some with Frost Restoration but they're out of stock. I suspect they're regular high temp paints repackaged as rad paints anyway1
I'll go with a heat resistant matt black aerosol.
23-06-2020, 04:12 PM
I just squirt some 'Tough Paint' satin enamel at it if it's looking a bit tatty.
25-06-2020, 01:17 PM
Aldi matt black stove spray can, £3:99.
Did mine 8 or so years ago and has never flaked. Andy
