BIG SEVEN FRONT SPRING SHACKLES
Which would be best/longest lasting shackles to use:
a. original big 7 with the threaded pins/bushes.
b. conversions big 7 to ordinary 7 pins/bushes.
I have both so presumably use up the Big Seven threaded ones?
(Bearing in mind I have heavier BMC A + engine and hydraulic brakes)
Dennis
