AD wings fitting
Hi All
Just getting around to fitting the correct wings and running boards to my AD tourer.
the first question is where the flitch plates mount to the body tub. Are they flush with the body side or set back so the front wing tucks under the body. If they are flush then it looks like the the running boards I have have insufficient width to bolt to the underside of the body flange.
Also I believe the wing mounting flange runs slightly downhill towards the front where it attaches to the flitch, could someone provide a measurement from the top of the flitch to the wing flange at the front and back.
Photos would be great if possible.
Many thanks
Adrian.
