24-04-2020, 07:45 PM
(This post was last modified: 24-04-2020, 07:46 PM by Ruairidh Dunford.)
Can anyone with a rod braked car post a photo of the handbrake please? The one I have fitted at the moment seems too far forward when off.
Many thanks.
According to the Parts Lists, the cabled-braked lever is 1A5489, the rod-braked one is 1A5564. The illustration used is the same in both Parts Lists, so I cannot advise just what the difference is.
The lever I have is leaning too far forward.
So the difference is in the position of the pivot point?
06-05-2020, 07:53 PM
(This post was last modified: 06-05-2020, 07:55 PM by Ruairidh Dunford.)
You tell me...
I suspect so but, until I find one to compare, I am surmising.
Well, from those two photos, the pivot point of the common version is halfway between the mounting rivets, whereas the rod-braked version is more like 1/3 - 2/3.
