4 Speed Crash Box Bearings
Can anyone confirm the 4 speed crash box bearings-
I have listed
Input or 1st motion shaft, Austin BH179 :   RHP LJ 1 1/4"   SKF RLS 10
Output or 3rd motion shaft, Austin BH 181:  RHP MJ 1"   SKF RMS 8
Layshaft: plain bearings
Talk to Andy Bird - he'll have the answers
Tony the ist motion bearing is an LJ35, output MJ1 and layshaft 5/8" bore plain bushes the 1st motion bearing same dimensions as 4spd syncro box without the circlip groove. Terry.
What Terry said.
LJ35G = SKF6207A I believe.
MJ1 at rear
There's also the little roller race on the input shaft but as far as I know they aren't obtainable.
1.875" x 0.46" x 1.125"
The roller bearing is replaced by an inter bush for 4spd box from A7 suppliers. Terry.
Didn't mean that one Terry (though you are right to add it) - the one on the front end of the 1st motion shaft.
(07-04-2020, 12:49 PM)Terrytuned Wrote: Tony the ist motion bearing is an LJ35, output MJ1 and layshaft  5/8" bore plain bushes the 1st motion bearing same dimensions as 4spd syncro box without the circlip groove. Terry.
Thank you for this -  I thought the input bearing I had listed seemed wrong.
