Car type: 27 Chummy
Hello All
I didn't want to hi-jack Stuart's post on "time to convert to 12v" but am interested in your experiences of night driving with the 6v system.
There have unfortunately been a couple of very serious accidents within the MCC at night with moderns ploughing into the back of vintage vehicles.
I have LED headlights but still not sure I am getting the best light.
What exact make and model of headlights are others using (there are so many out there). Does it make a difference which model of reflector is used in the headlights.
Do some of you also provide additional rear lights (flashing) and are they legal for vehicles travelling over 25MPH.
Many thanks.
Adrian.
I run with a completely standard 6 volt system on my RM; the 6w bulbs in the standard Lucas 582 rear lights provide ample brightness to be seen - they are brighter than many more modern cars on the road - and coupled with decent reflectors there is no good reason why anyone should 'plough into the back of me', except for lack of attention, and no amount of illumination can cater for that! The standard dynamo can't keep up with consumption at night, but I have no problems running for up to two hours at night without any signs of the battery running down.The only problem I have is with the headlights which fade into oblivion when a modern comes up behind ...
26-10-2017, 02:13 PM
(This post was last modified: 26-10-2017, 02:16 PM by Rick F.)
Two of my sevens have LED lamps all round. The headlamps are fitted with the Seven Workshop "standard" 6.5inch reflectors (one with pilot light, one without). I believe these were originally intended for scooters or mopeds, but I may be wrong.
Whilst these provide a much better forward light, the biggest advantage of LEDs, to my mind, is the improved performance of tail and brake lights, which hopefully alerts any sleepy modern driver and prevents a rear end shunt.
As regard whether additional flashing lights are legal or not, I think we worry too much about legality at the expense of being seen clearly at night (and during the day). In fact, having read an article in the latest FBHVC News, it seems that most LED headlights ( and flashing indicators) are in themselves illegal, as they cannot meet the specified wattage for these applications. However, legality looses out to visibility as far as I'm concerned and I have no intention of reverting to filament lamps.
Rick
In deepest Norfolk
I also have 6V LED rear lights which are very bright.
It seems to me that at night there is a real danger of cars coming from behind misjudging the distance.
The A7 is so small and the rear lights may well be on each end of the number plate so not at the full width.
The result is that the car appears to be much further away because the lights are close together.
My cars are the same set up as AustinWood's and I agree exactly with what he is saying about misjudging distances.
I have fitted a small bicycle rear light, one of those that has a single very bright red LED, on a redundant screw, low down on the offside rear mudguard.
It is not very obvious, until it is on, and then it is uncomfortably bright if you get too close.
I hope the following modern thinks "it's one of those pesky cyclists - slow and wobbly" and acts accordingly.
I have also stuck a large, cheap, roadside size reflecting triangle on the spare wheel.
Horrible, and very obtrusive.
But I have been pleasantly surprised by the number of cars that stay well back, even where there is room to overtake.
I would much rather be seen than squashed.
Simon
