Car type:
no - too early. Try behind the rear mounting on the other side. And if not, just in front!
Scratch through the paint. N/S edge of the rail.
Car type: Austin Seven RP 1932
Thanks JonE, I'll look again tomorrow (weather permitting) Cheers.
10-11-2019, 07:46 PM
(This post was last modified: 10-11-2019, 07:47 PM by Reckless Rat.)
On my RP the chassis number is on the nearside chassis rail, to the rear of the rear n/s engine mount very close to where the bulkhead meets the chassis. If you have deflector plates fitted there is a screw holding the plate to the chassis with a 'P' clip that holds the fuel pipe. Look just rearwards of that.
11-11-2019, 12:02 AM
(This post was last modified: 11-11-2019, 12:03 AM by Smiley.)
Thanks R/R for the Input.
Thank you Martin. That will be very helpful.
Mine is also as reckless rat says good luck
