Car type: Ruby mk 2
Hi
How does the Ruby ARR indicator switch dismantle.
Trying carefully leverage under the edge but don’t want to damage the bakerlite.
Tim
The horn push and indicator switch assembly is attached to a 3 foot long hollow "stator tube" that goes all the way down inside the steering column. The wiring runs down inside this tube. The tube emerges just below the steering box. To get it out, disconnect the 4 -core cable under the bonnet, then release the pinch bolt around the tube on the steering box. The whole tube and switch can then be pulled up into the car. Only then can the switch be inspected/cleaned/repaired.
Car type: Ruby mk 2
Thanks chaps.
Just what I needed
