A7 Parts Number
Does anyone know if there is a comprehensive list of the A7 parts numbers.  From Austin there are lists in the Parts Books and the Index Cards which I guess informed the Source book. But are the any other sources for the numbers, apart from the numbers stamped on the parts?
I would think the short answer is no- you have identified all the sources that I am aware of.
Do you have a reason for needing more ?
Hi Douglas,
 Austins did produce a   'Table of Suggested Stocks of Spare Parts'  I have a copy which covers the years 31 to 36  and is indexed by part number within part type. I suspect it follows the numbers in the spare parts booklets.
The service journals are also a good reference for new introduced part numbers. Let me know what exactly you wish to look up.
  regards  Russell
Hi Russell thanks for this, I presume you mean this book on the Association Archive.
http://www.archive.a7ca.org/wp-content/u...R_A010.pdf
Thanks Russell - another book to chase !
The Archive copy dated 1939 seems to cover 34 to 38 so there might be more ?
Yes Douglas, but mine is the earlier edition that relates to sevens back to 31
Any chance of uploading it please?
Peter
