Hi can any one have information speedo Drive
hi I looking for any information on early drive unite from chassis rail to the prop shaft
I have one but it has bits missing and damaged any photos ect would be helpful.
Regards Andrew
Dave Dye (Austin in the shed) made me up one of these a few years back - very good it is too.
David Cochrane has the chassis bracket and the spring drive belt for these I believe. The propshaft pulley is wooden and made in 2 halves nailed together
This came up a while back and I posted some photos
http://www.austinsevenfriends.co.uk/foru...97#pid7797
The propshaft pulley on mine is aluminium with 2ba bolts.
Suffolk, UK
1925 Chummy
1934 Box
Hi thanks for the reply’s will follow up now I know what
Iam looking for,I have the wooden pulley
The prop pulley should be alum,bolted together with 1ba screws.
The drive head was mazak and usually either worn or broken off .
Phill Witter and Scott had the compleat set up on their stall at Beaulieu, I dont think they sold it
I believe this is the cable you need
https://www.ebay.co.uk/itm/Austin-Seven-...Sw5uJdAqvd
P.S ebay also found this
https://www.ebay.co.uk/itm/1920s-SPEEDO-...Swrwdc7Qyp
I can't believe the price especially as it doesn't include postage - perhaps that's because the seller needs to hire security guards to accompany him to the post office! lol
