5 Location: Oakley, Hants, UK
Picking brains.
I made a stupid mistake when rebuilding my Hadley Crankshaft engine and ruined a 1 15/16” splash fed Conrod .
To cut a long story short, I am unable to get a replacement.
Can I fit Phoenix rods as an alternative?. Can I get Phoenix rods with the 45 degree big end joint.
Tony Betts (http://www.7ca.co.uk/index.htm ) has Hadley conrods be it in 1 1/2 inch..... but maybe he can be of help. If not make haste to order with Phoenix as they have manufacturing a batch of crankshafts and conrods planned for late this summer (I know as I've ordered a crankshaft with conrods for my Rosengart with Phoenix.....)
Derek the answer to your questions is no. Tony or one of the other second hand dealers will no doubt have a big box of 1 5/16" splash rods, if your journals are std, you may even be able get a rod that has been metalled for an undersize crank, you can then bore it out to suit your's. I have successfully done just this on more than one occasion.
All 1 5/16 cranks should all be machined to the same jernal width. So you can fit austin pheonix and HADLEY rods.
Same with the 1 1/2, only they are actually a metric jernal to take shells.
Pheonix do not make the 45% rods,
Here's the sad part, I used to make the 1 5/16 rods on 45%. But the profit margins were just to small. Making £50 a set pushes me to close to the vat level. Same as some of the other large items I'm looking at making, meen I have to stop doing some smaller items.
I'll have a word with mark at pheonix in a bit about rods, as he is dropping in on me latter to take about the next batch of crank and rods.
Thanks for all the comments and help. It’s a bit like London buses , you wait for ages and two come along.!
I now have two 1 5/16” Hadley con rods so if you have one of the ten Hadley 1 5/16” splash fed cranks I have the only spare in existence and that will ever be.
