Hi, Yes this is the same unit that has been on test, Ian Mason-Smith emailed me to say that it was launched this week but at present it's only in 12v -ve earth format.
Dave (cold & sunny Cumbria)
A 6v version is a week or so away from completion, in prototype form - I suspect this will be a better seller for them than the 12v version.
If trials prove successful it could then go into production quite quickly - so they tell me.
45 amps at 12 volts. Can the drive gear arrangement cope with this?
From the picture it looks as though thedistyributor is horizontal instead of vertical.
I’d say from the pictures that it’s even worse than that. About 20 to the hour
I have written to tell them this - the one in the picture is not correct.
I suspect that a magneto engine version would sell well since usable dynamos are thin on the ground and cost about the same
Charles
I think you are quite correct there Charles.
