Re setting rear springs
The Ulsteroid rides a bit low at the rear for trials, the springs have about an inch of set on them when fitted and the weight of the car is on them. I have to rebuild the axle in a couple of weeks and was wondering if sending them to the local black smith to have a couple of inches more set put in was a viable option? I dont know if its just a case of heating them up and bending them, or if they have to come apart and be completely rebuilt. if the latter then new springs are probably a better option.
Stuart.
(03-10-2017, 04:33 PM)Special Bits Wrote: The Ulsteroid rides a bit low at the rear for trials, the springs have about an inch of set on them when fitted and the weight of the car is on them. I have to rebuild the axle in a couple of weeks and was wondering if sending them to the local black smith to have a couple of inches more set put in was a viable option? I dont know if its just a case of heating them up and bending them, or if they have to come apart and be completely rebuilt. if the latter then new springs are probably a better option.
Stuart.
This shows the problem, add 25 stone to the car and it sits down at the back considerably. As I have entered the MCC Exeter trial I should probably try to stop the spare wheel well hitting the rocks!
[Image: 16996138_1407745462630313_53964292213076...e=5A7B28A0]
Would it be best to ask your blacksmiths advice first ?And cost too.
Its only knocking out the 1/2" rivet to separate the leaves . If you fit new springs they may be weaker/stronger than the ones you have now and not having the camber you require.
(03-10-2017, 10:53 PM)Austin in the Shed Wrote: Would it be best to ask your blacksmiths advice first ?And cost too.
Thanks Dave
Yes I'm afraid new springs will be too stiff. Unfortunately I'm working away a lot at the moment, hence asking here, but yes I will have to make contact with one of the surprising number of black smiths around here.
Stuart.
Users browsing this thread:
