Warning [2] Undefined array key "useravatar" - Line: 6 - File: inc/functions_post.php(948) : eval()'d code PHP 8.1.32 (Linux)
/inc/functions_post.php(948) : eval()'d code 6 errorHandler->error_callback
/inc/functions_post.php 948 eval
Warning [2] Undefined array key "userstars" - Line: 11 - File: inc/functions_post.php(948) : eval()'d code PHP 8.1.32 (Linux)
/inc/functions_post.php(948) : eval()'d code 11 errorHandler->error_callback
Chummy floor pan
Hi all,
I have just bought a Chummy project with a very rotten floor pan, does any one have a drawing for the floor pan?
Tim
(03-10-2017, 09:52 AM)Timww0 Wrote: Hi all,
Tim
Good fellows creative metalwork make new floors, tel 01382 320284 email metalwork@ossians4.co.uk
You can see the quality of Andrew Goodfellow's work on his Facebook page Creative Metalwork. First image on his page is of a new floor pan for a PD Tourer.
https://www.facebook.com/298672886833601...=3&theater
Jeff.
I have already helped build two AC floors and a Ruby floorpan by correspondence (Sydney, New Zealand, Katherine - Northern Territory) and may be able to help him with yours - you only have to let me know what model you have.
Bill in OZ
Tim
Hi Tim, I do not have drawings but I do have an original AD floorpan (currently separate from chassis and body) in original un-restored condition (currently awaiting attention!). It has surface corrosion and only some small local areas that need repair so it would be fine for checking dimensions or to use for producing a drawing. Not sure where you are based but I am in Bristol and if am happy to help if I can.
Good luck!
Dan
Tim
Good luck!
Dan
Hi Dan,
That would be brilliant if I could come and measure it. I did send you a private message, did you get it?
Tim
Tim
Good luck!
Dan
Hi Dan,
Tim
Hi Tim, yes just seen you PM and will be in contact shortly.
Cheers,
Dan
BILL
I am picking up on your thread of 2017. My 1926 Chummy has a floor that is shot.  I managed to acquire a new floor pan on eBay. Right now every thing is stripped off just leaving me with a bare shell.  I do not wish to make any mistakes.  I would like to hear of the best procedure to remove the old and fit the new floor.
Kind regards
William Cuddy. Cork. Ireland
Guess what I've been up to this morning.......
I see a hand print and what appear to be two bottom prints Martin - just what have you been up to??!!
