Ulster exhaust
Hi, would anyone have a drawing for the Ulster exhaust can? With the pipe dimensions for either end to. If someone would be willing to email a drawing or post it I would appreciate it. John
Not a 'drawing' as such John but I have a side view sketch, I could post or e-mail you a copy if it helps?
I've just made one for my car so let me know if you'd like some suggestions about how to tackle it. Otherwise Chris Gould's book 'A Guide to Building Reproduction Austin Ulsters' is probably the best reference you are going to find.
The outlet pipe is 1" OD, the tailpipe 1" ID and 1.125" OD. You'll probably need to match the inlet to your exhaust manifold.
Your sketch would because great help Chris. I will try to send you a PM with my email address. Appreciate it
I sent you a PM on the exhaust as well Chris
Thanx
Greig
Messages received! Sketch on the way...
