Car type:
I note there is one "Austin 7"/Datsun car at Beaulieu - the one brought back for patent infringement checks. Is anyone an expert in these things or are there any more over here? I'd be interested to know how the construction process occurred; chassis, bodies and so on.
Didn't Austin send a team out to Japan in 1953 to show them how to build cars?
Was there any truth in the story that the Austin 1200cc engine Somerset/Devon cylinder head would fit straight on the Datsun 120 Y ?
I believe there is a Datsun at Gaydon or is it the same one?
I did get a close look at a 1935 Datsun a few years back, which was on display in the reception area of a well-known Japanese car maker's design HQ. Sadly I was denied permission to take any pictures. It certainly bore a superficial resemblance to a Seven, but in detail it was a quite different car.
Car type:
thanks Chris - so which cars had the Austin chassis' and are they recorded as chassis numbers in Austin manner?
Don't know about the 120y cylinder head, but Austin did help set up a plant that initially produced A40 Somersets in Japan in the early 50s.
Car type:
Peter - that's very interesting. Is that over 'ere or over there?!
Is that in the same position as the Austin GE chassis plates.. and was it chassis rail stamped too?
