12-05-2019, 01:53 PM
I have just removed my ammeter to fix a loose glass and upon re-installing it I couldn't remember which
side the wires had come off from so I tried one way and then the other.
I now have no lights and no spark to the plugs.
If I had connected it the wrong way round initially, might I have damaged the lighting switch or something else please?
I'm about to start checking wiring etc. but any thoughts would be gratefully received.
I've checked the main fuse and that seems okay but will check it again.
The vehicle is a '37 Ruby with positive earth.
Many thanks for your time.
Graham.
Graham.
