The thrust side in the 'closed' side (i.e. the bit with the writing on) as per your first photo.
The 'pink' side of this angular contact bearing is fitted toward the crown wheel carrier, the outer 'blue' ring is fitted into the diff housing.
Thanks Tony,
Any chance you can explain how you picked which side was the thrust? I assume it's because the "closed side" allows force to be applied to the centre of the ball but maybe that's not it.
Thanks again for the reply
Steve & Tate Davidson
Perpetual Amateur Austineers
Think of the angular contact bearing as a cross between a radial ball bearing and a ball thrust bearing - the raised shoulders on the inner and outer ring are 'thrust' faces - the axial thrust causes the balls to 'ride up' these thrust faces .
The reduced shoulder on the non thrust side allows for installation of a larger number of balls, increasing the axial and radial load capacity.
13-05-2019, 11:20 AM
(This post was last modified: 13-05-2019, 11:25 AM by steve davidson.)
Thanks for the explanation Tony, you are all very generous with your knowledge. I like knowing what to do, but l love knowing why and your answer has provided that answer.
Thanks Paranzie, your explination and drawing are much appreicated
thanks for the info
