Super pictures Ian!
I'm guessing the mirror had to be up there to see past those hats!
I like the second photo where the proud owner has added
a more powerful horn, an RACNZ badge? Plus looks to have added
wing stabilising struts to stop his front wings shaking?
And another set of tyres?
Great photo I very much like the upright stance
which my Cup special is adopting.
Bill G
I think the struts are likely to be damper mounts, remember early chassis have no provision for mounting such a device so in this case it appears to be bolted to the axle and then up to the cow horns
The Austin script is an Austin Twenty item, and appears to have been standard fitting to most 1923 cars (but not 1924 cars)
My Triumph TR3A rally car has standard twin Lucas horns,
But also Marchal spot lights , inc a roof lamp , plus Marchal
(police grade)alternating air horns, which is handy if you want someone to pull over!
Or are in a rush to get to A&E...
Only used on Continental rallies of course. :-)
Bill G
Ps presumably a train horn needs a big big battery?
They run a compressor feeding an air storage tank, this being of a considerable size and often awkward to mount on anything other than a larger car.
What great shots Ian - Thank you. Would suggest it's an early 1924 rather than 1923, as the front axle seems (to my eyesight) to have the bossed provision for shockers, but none there. These axles were available in early '24 and whether you had to pay extra for shockers at the time I don't know. Maybe they were undecided if really necessary, as I have photos of several cars (including one of Waite competing in a trial with a Factory chummy) with these axles, but no dampers fitted. Re the Script badge, I thought that only the factory-owned cars had these fitted, not every car, so pleased to find I was wrong. The car in your photos has the second type of crankhandle, which also would make it not 1923. Hope this helps. Cheers, Bill in Oz
