thats production engineering for you. Feed rate chosen to suit high volume, not finish where it wasnt neccassary. The poor sod who turned it up was probably on piecework.
id grease it up it were me. tjats what i do with the tubes that go down the middle if it.
Even so that's a shocking amount of time on a lathe for a component which doesn't much seem to need it.
+1 for grease.
Hedd's comment on piecework put me in mind of a factory I visited many years ago. I was introduced to an operator who had been centreless grinding 1" diameter tubes, around 12" long, for the last 15 or so years. It also put me in mind of Arthur Seaton's job at " The Raleigh " in Saturday Night & Sunday Morning.
Paint with KBS Coatings Rust Seal, if you can find some (Holden?) It goes a very long way.... 113ml (1/4 pint..4oz) covers 6 sq foot with 2 coats. Google KBS coatings for full info. - OR - POR 15 similar but not so good.
I think grease would just dry out again.....especially in the tropical west-country!
Dennis
I’ve had another close look this morning and there is not much clearance as this shaft slides through the bush on the outer shaft, any paint in the wrong spot might make things a bit too tight.
Looks like it’s going to be a nice covering of grease for this one when it goes back together!
-A
Penetrol or CRC Soft seal if you are really troubled by the potential of future corrosion.
25-04-2019, 07:01 AM
(This post was last modified: 25-04-2019, 07:09 AM by Tony Press.)
Wipe over with Ranex Rustbuster ( Phosphoric Acid) then oil.
It's survived 80 or 90 years with no more than a bit of surface rust, why do you feel there is a problem? Cosmetic finishes are for visible parts. A lick of grease and you're good to go.
