Rear Spring Question
Apart from the camber are all rear springs the same length?
Mark
Yes I am pretty sure that is the case.
Depends what you mean by the same length.
The distance between centre of the vertical bolt hole and the centre of the spring eye is the same for all cambers.
Thanks Ian and Nick,
I have some old Chummy springs that I wanted to give the springworks as an example rather than taking the car off the road so as they are the same length I can now do that.
I was thinking of 2 1/2" camber and reasonably soft for my special that  weighs about the same as a bare chassis.
Mark
The sports springs I sell have two and a half inch camber.
Ian, If springs were not so heavy I would buy them from you, thanks for the confirmation about the camber.
Mark
Sports springs weigh 5kg each.!
