I am a bit ashamed I need to ask this but how exactly do you use the acorns and the little brass disc with the hole and slit in it when attaching leads to the distributor?
Obviously the central core goes through the hole in the disc but then what? Are you meant to fold the core back and somehow catch it with the slit? Or is the slit just there to provide a step to catch the wire as you tighten the acorn down, a bit like a split lock washer?
Whatever way it goes there doesn't seem to be any cable strain relief at all. It's all just held by that central conductor.
Simon
Simon, simply spread the exposed copper strands out like a "star burst", they are then gripped by the brass washer when the acorn is tightened. John
Hi John, that makes sense for normal wires. I failed to mention though I am using the non copper wires sorry. These are the Accuspark carbon core leads. The central core is a strong coil of sorts, but a single strand if that makes sense. It could be unravelled but not spread out like a normal multi-core wire.
The carbon core is very tough. I was surprised actually. I actually cut off the modern booted plug ends and put on my own crimped ring connectors then some black heat-shrink over them. I was able to double the core and do a very solid crimp using the proper tool on the plug end. I use thumbscrews to hold them on.
I suspect just poking the solid core through the hole and folding it over will be enough to make a decent connection. I just wondered how other people did it.
Simon
I used to cut off a bit of a paperclip, bend one end into a circle (size of your washer) and the other end, bend perpendicular to the circle and push it into the carbon conductor. It only needs to be long enough to grip into the carbon core. Crude, but effective.
The accuspark carbon leads with my electronic distributor came with some gold plated bent paper clip type things that push up the end of the lead. From memory, they were flat sheet folded into a U shape and cut with a pointy end and barbed edges.
Peter
Car type:
just watch that your brass inserts are all the same depth in the accuspark distributor cap, as of course you need the pressure provided by the acorn to create the contact. This should be obvious by the lead getting tight but I missed the problem first time round just because I wasn't expecting it.
You can either use a volt meter on the lead to detect when it fires or simply set the rotor arm pointing to the very corner of the baseplate - that always works for me.
I actually just removed No. 1 lead and hooked it to another loose plug sitting on a head stud then I was able to rotate it and see where it sparked. I am in about the right place I think. I could see the voltage on the meter too. An analogue meter would be much better than my digital here.
It is also possible to attach the little brass discs with small brass screws, these give a more positive connection than the paper clip thingies. Funnily enough, I was doing exactly this at the weekend.
