01-04-2019, 05:53 PM (This post was last modified: 01-04-2019, 06:08 PM by J Faulkner.)
Hi all was just wondering what time the hand over of JH 5024 the ex Dave Wilcox box saloon will be on Saturday 6th April as would like to see it in the flesh again if welcome and maybe give the Ulster rep a run out, many thanks Joe, im sure Dave would be very proud and approve of the car being involved with the scheme, he did alot for our club and group, and also helped us put the Ulster together lending us a bottom end engine when we broke the crank in half! All the best and look foward to the 2019 season
Thanks Tony, she don't look bad after a bit of a winter makeover, really chuffed with the 17s on the front to match the rear has changed the look of it, plus that rebuilt gearbox by Andrew bird, looking foward to going out in it,
Your a good one thanks Tony, will sort out with you, we sent him 2 cranks and 2 sets of rods so he would sort out the best, only wanted one set doing and matching to the crank, glad being sorted, also could do with a bigger speedo cable as the one we found isn't long enough so will have to come see you, needs to be around 22 inch, Thanks Tony
