Sounds like 3/16" BSW if coarse or 3/16' BSF if fine (2BA is approx 3/16" diameter).
10.24 UNC might be ok & easier to find...
Thanks Bob and David,
Someone has confirmed that the thread is 3/16BSF, all I need to do now is find some. Ruairidh's photo on the clutch spring thread shows that they have Cheese Heads.
I thought they were 2BA, at least I have a pot of brass cheese heads at work that fit and I thought they were 2BA. They are too long but I'll happily send you some if you would like, it's a large pot.
Marcus,
They are 3/16" BSF but 2 BA will do the job as there is no great strain on them They are cheese head and are fitted with washers.
And are fitted with springĀ washers if I remember.
10-32 UNF screws might be easier to find and will directly substitute for 3/16" BSF if you're stuck.
Thanks Tom, Chris and Tony,
I tried some 2BA which I have here, but they didn't go in very far before they jammed.
2BA has a tread pitch of 0.81mm and 3/16BSF is 0.79mm pitch. I could force the 2BA in but will try and get the correct screws first.
Well, you could express 3/16" BSF as 0.79375 mm pitch, most people would say it's 32 Threads Per Inch which happens to be the same as 10-32 UNF
