19-09-2017, 08:44 PM
I have recently been loaned this tappet shown below in my quest for non adjustable Ulster tappets.
I wonder if anyone can tell me what it is from?
Mystery Tappet.
21-09-2017, 10:26 PM
Hi Robert,
Would you be able to post the measurements Please Colin
22-09-2017, 07:42 PM
Colin,
the tappet is the same length as a standard adjustable one. The cap is 7/16" diameter and a nominal 1/4" high when fitted to the tappet. Do you perchance have any thoughts about it?
22-09-2017, 09:14 PM
Hi Robert,
Judging from those sizes when fitted would have about 5/16" gap between cap & valve stem even with a high lift cam would still leave 1/4" My thinking is did they use longer stemed Valves in the Ulster Engines The removable cap does allow for catering for different length valves ether by making a longer cap or grinding the cap down Hope that as not confused things more Colin
22-09-2017, 09:26 PM
Yes I believe they did use longer valves and different springs, I can not however say for sure that this is an Ulster follower.
22-09-2017, 09:51 PM
they used longer valves in the grasshopper.
23-09-2017, 12:22 AM
Could they be Brooklands tappets? seem to remember a period spec that mentioned longer valves in the Brooklands motors. Also see here. http://www.motorsportmagazine.com/archiv...orts-model
23-09-2017, 06:24 AM
Ulster valves are longer than the standard ones and are tulip type.
