Sports brake bracket brass ferruls
Hi,
I am replacing the brackets that fit to the rear cross member for the rear brake cables on my special and don't have the ferrules which go inside them. Does anyone sell them/know which plumbing fitting they are please?
David
Hi david,
I have them here at £2.50 each. Plus p&p
www.7ca.co.uk
If you entre rope guides, you should find the seven workshop, david cockrane and John BARLOW also have them.
Tony.
Hi Tony,
Thanks, I couldn't work out what they would be called! Will be in touch!
regards
David
