11-03-2019, 10:44 PM
I'm working on a superchaged Ausin Seven racer ![Smile Smile](https://www.austinsevenfriends.co.uk/forum/images/smilies/smile.png)
Have some difficulties understanding a few things, espacially the lubrication of the supercharger.
First of all the supercharger is mounted towards front from engine block. All photos of other I have found superchargers seem to be mounted the other way around, beside the engine block below exhaust manifold.
What would the orgon of this setup be?
Next there is a number of nozzles, mostly for lubrication I assume, that I need to understand how the should be connected.
See the photos where I have marked the different nozzles with red letters A-G
A: In the rear on engine block
B: Adjustable valve on supercharger
C: Threaded hole beside B
D: Center of crankshaft (assume that this is oil pressure out?)
E: Threaded nozzle with on/off valve on front end plate of supercharger
F: Second nozzle on front end plate of supercharger
G: Nozzle on front of engine block
Would very much appreciate to get some guidance on understanding and how to connect these nozzles / lubrication points.
![[Image: 1.jpg]](http://optonoviracing.com/wp-content/uploads/1.jpg)
![[Image: 2.jpg]](http://optonoviracing.com/wp-content/uploads/2.jpg)
![[Image: 3.jpg]](http://optonoviracing.com/wp-content/uploads/3.jpg)
![[Image: 4.jpg]](http://optonoviracing.com/wp-content/uploads/4.jpg)
![[Image: 5.jpg]](http://optonoviracing.com/wp-content/uploads/5.jpg)
![[Image: 6.jpg]](http://optonoviracing.com/wp-content/uploads/6.jpg)
![[Image: 7.jpg]](http://optonoviracing.com/wp-content/uploads/7.jpg)
![[Image: 8.jpg]](http://optonoviracing.com/wp-content/uploads/8.jpg)
Conny Gillström
Conny Gillström
