Are you restoring a museum piece or enjoy driving a vintage vehicle - for me, if you can afford it, go for new.
Hi Darren,
I had a similar issue with my sports, it was not leaking but was full of rust and snot. I made the mistake of filling it direct from the bowser and the fuel gun stirred up years of sediment and 500m down the road I stopped with a blocked carby.
I pulled the tank out I got rid of the worst muck by dropping in a few handfuls of nuts and bolts and rattling them around, then rising out. It took a few repeats of this before I stopped getting flakes of rust out.
I then used a product called KBS motorcycle fuel tank sealer repair kit (from ebay) and it's worked a treat. From memory it was a three stage process but didn’t take long.
It cost less than $100 and since then I’ve done a few thousand km without any issue.
Steve & Tate Davidson
Perpetual Amateur Austineers
Ruby fuel tanks are not rare items. Why not find a better condition original one from a cherished supplier and if necessary use tank sealant on it?
I would try what Steve suggests and if it's too far gone, as Nick points out, it ought to be possible to find a Ruby tank in decent condition. Then it's still a vintage vehicle...
Sorry Darren I don't mean to insult your intelligence but this is one of those threads where someone really ought to say whatever you do, don't attempt to weld it - very dangerous indeed.
I have a tank that £30 would secure. I would and have used the product suggested in any tank that I was to install.
06-03-2019, 05:13 PM
(This post was last modified: 06-03-2019, 05:21 PM by Darren D.)
Definitely not a museum piece or garage queen. My intentions are to restore a usuable classic that I can put some mileage on.
Hi Chris,
No insult taken. My inttenion was to always give it to a specialist to work on. The only thing I have done is take the sender off.
Hi Nick,
The problem with buying second hand is you run the risk of inherenting somebody else's problem. I've also heard most sealants breakdown into the fuel lines over a period of time.
Well, the very secondhand one that I bought and sealed using Frosts products about five years ago is still doing fine on my Ruby - but of course you pays your money and takes your choice.
