Brakes
Just a quick one here.
A7 Arr
Does the handbrake work on all four wheels ?
Tiger - if you're indicating that your car is an ARR -ie- Ruby-type, then answer is yes.  Any chassis with the longitudinal strut up the middle indicates that all brakes are coupled.  Good Luck, Cheers,  Bill
Thanks Bill
Seems like I have a problem mine only operating on the rear.
