Short 6v battery
I normally fit the 80ah 6v Exide batteries but for the latest application I have found that it is 2cm too high!
can anyone recommend a suitable 6v battery which is no greater that 19cm high please?
Almost this one ?
https://www.ebay.co.uk/itm/Vintage-Car-B...rk:26:pf:0
Or brave enough to saw off half the battery ??????
https://www.ebay.co.uk/itm/Audi-A6-Car-B...rk:35:pf:0
Depending on how critical length and width are, you may find a suitable one at Shield Batteries. The table gives height and total height:-
https://www.shieldbatteries.co.uk/documents/classic.pdf
Not used this make myself.
Ruairidh
Have a look at this Banner 6 volt battery H 191mm from Eurobatt:-
.jpg   077 18-480x360.jpg (Size: 20.8 KB / Downloads: 216)
Bryan.
This is all excellent and very helpful - thank you all!
