DVLA Vehicle Check Improved
This may be old hat to a few of you, but I have recently found that the online DVLA vehicle check has been improved by dropping the need to enter the vehicle make.  This used to be problematic for old vehicles, where some odd things had been put down in the past for the maker such as "Austin Convertible" which would not show up if Austin were searched for.   Now, simply entering the registration is enough.
In addition, the MOT history check only needs a registration and no Chassis Number or VIN is required.
Yes much better isn't it. https://vehicleenquiry.service.gov.uk/ViewVehicle
https://www.check-mot.service.gov.uk/
