block 157834
good clean condition; top and bottom have not been refaced - still have number stamps. No cracks around the cylinders or water holes. Bores are 2.20 but needs honing at least... some rougher areas where surface rust was. Core plugs removed.
Acid stripped and bare.
Just found a crack linking to the lower water outlet. May be longstanding but someone may be able to assure themselves it's useful, (perhaps for its serial number).
Numbered block...  1932 ish? (later type core plugs)
£25. pm for photos.
Where are you based Jon?
Sussex...
