06-01-2019, 09:17 AM
Hi All
Slightly confused regarding the fitting of an isolator switch to my special.
Initially I was planning to fit a Lucas unit to the dash next to the starter button, breaking the + positive circuit (6v neg earth system).
However the instructions state fitting to the earth circuit, the battery is fitted underslung passenger floor some way from the dash.
Question is, would I then have to run the negative earth cable from the battery to the isolator and then to earth ?
A friend with a Seven has suggested fitting to positive circuit on dash prior to push start button, any thoughts.
