Austin Ruby Mk2 ARR
Hi,
Firstly thank you to those who assisted with my post regarding the brake light switch. Much appreciated.
Some advice regarding the petrol gauge fault would be great.
When switching the ignition on the needle lies dormant. When switching the ignition off the needle jumps momentarily. I have replaced the fuse as the original looked past its prime. There is power here confirmed by a
functional brake light, both services using the same fuse box. The trafficators are disabled?
All help greatfully accepted.
Thank you.
Regards,
Paul t
